GPIO Motor - 步进电机驱动
SDK 内置了步进电机驱动,支持驱动两路步进电机,适用于 2803 系列步进电机驱动芯片。该驱动通过 GPIO 控制步进电机的相位信号,可实现精确的步进控制,支持多种运动方向和速度调节。
其电路连接如下图所示:
image-20241230134353237
驱动配置
内核驱动配置
执行 make kernel_menuconfig 进入内核配置驱动,前往下列路径
Allwinner BSP  --->
Device Drivers --->
Misc Devices Drivers --->
<*> Allwinner gpio motor 2803 driver
image-20241230135951568
设备树配置
步进电机的设备树配置如下,只需要修改对应的 IO 到对应的引脚即可:
gpio-motor@0 {
compatible = "allwinner,gpio-motor";
ab-pin-black = <&pio PD 12 GPIO_ACTIVE_HIGH>;
ab-pin-yellow = <&pio PD 13 GPIO_ACTIVE_HIGH>;
ab-pin-brown = <&pio PD 14 GPIO_ACTIVE_HIGH>;
ab-pin-blue = <&pio PD 15 GPIO_ACTIVE_HIGH>;
cd-pin-black = <&pio PD 16 GPIO_ACTIVE_HIGH>;
cd-pin-yellow = <&pio PD 17 GPIO_ACTIVE_HIGH>;
cd-pin-brown = <&pio PD 18 GPIO_ACTIVE_HIGH>;
cd-pin-blue = <&pio PD 19 GPIO_ACTIVE_HIGH>;
正常配置后会生成节点 /dev/sunxi_gpio_motor
image-20241230140227535
模块使用
GPIO Motor 支持使用普通文件I/O读写或 IOCTL 控制
* Copyright (c) 2019-2025 Allwinner Technology Co., Ltd. ALL rights reserved.
* Allwinner is a trademark of Allwinner Technology Co.,Ltd., registered in
* the the people's Republic of China and other countries.
* All Allwinner Technology Co.,Ltd. trademarks are used with permission.
* DISCLAIMER
* THIRD PARTY LICENCES MAY BE REQUIRED TO IMPLEMENT THE SOLUTION/PRODUCT.
* IF YOU NEED TO INTEGRATE THIRD PARTY’S TECHNOLOGY (SONY, DTS, DOLBY, AVS OR MPEGLA, ETC.)
* IN ALLWINNERS’SDK OR PRODUCTS, YOU SHALL BE SOLELY RESPONSIBLE TO OBTAIN
* ALL APPROPRIATELY REQUIRED THIRD PARTY LICENCES.
* ALLWINNER SHALL HAVE NO WARRANTY, INDEMNITY OR OTHER OBLIGATIONS WITH RESPECT TO MATTERS
* COVERED UNDER ANY REQUIRED THIRD PARTY LICENSE.
* YOU ARE SOLELY RESPONSIBLE FOR YOUR USAGE OF THIRD PARTY’S TECHNOLOGY.
* THIS SOFTWARE IS PROVIDED BY ALLWINNER"AS IS" AND TO THE MAXIMUM EXTENT
* PERMITTED BY LAW, ALLWINNER EXPRESSLY DISCLAIMS ALL WARRANTIES OF ANY KIND,
* WHETHER EXPRESS, IMPLIED OR STATUTORY, INCLUDING WITHOUT LIMITATION REGARDING
* THE TITLE, NON-INFRINGEMENT, ACCURACY, CONDITION, COMPLETENESS, PERFORMANCE
* OR MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
* IN NO EVENT SHALL ALLWINNER BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT
* NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
* LOSS OF USE, DATA, OR PROFITS, OR BUSINESS INTERRUPTION)
* HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT,
* STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
* OF THE POSSIBILITY OF SUCH DAMAGE.
#include <errno.h>
#include <fcntl.h>
#include <linux/serial.h>
#include <stdlib.h>
#include <string.h>
#include <sys/ioctl.h>
#include <sys/stat.h>
#include <sys/time.h>
#include <sys/types.h>
#include <termios.h>
#include <unistd.h>
/* dir mode define */
#define DIR_UP 0x01
#define DIR_DOWN 0x02
#define DIR_AB_SHIFT 0x00
#define DIR_RIGHT 0x01
#define DIR_LEFT 0x02
#define DIR_CD_SHIFT 0x02
typedef struct sunxi_motor_device_status {
int x; /* X-coordinate step of the motor device */
int y; /* Y-coordinate step of the motor device */
int dir; /* Direction of movement of the motor device */
int status; /* Motor device status */
} sunxi_motor_device_status_t;
typedef struct sunxi_motor_cmd {
int dir; /* Direction of rotation for the motor command */
int ab_step; /* Number of steps to move the motor in up and down dir */
int ab_time_per_step; /* Time duration for each microstep in up and down dir */
int cd_step; /* Number of steps to move the motor in left and right dir */
int cd_time_per_step; /* Time duration for each microstep in left and right dir */
int block; /* block flag for motor commands */
} sunxi_motor_cmd_t;
/* ioctl define */
#define MOTOR_DRV_MAGICNUM 'm'
#define MOTOR_DRV_SET_STOP _IO(MOTOR_DRV_MAGICNUM, 0)
#define MOTOR_DRV_SET_STOP_AB _IO(MOTOR_DRV_MAGICNUM, 1)
#define MOTOR_DRV_SET_STOP_CD _IO(MOTOR_DRV_MAGICNUM, 2)
#define MOTOR_DRV_SET_START _IO(MOTOR_DRV_MAGICNUM, 3)
#define MOTOR_DRV_SET_BLOCK _IOW(MOTOR_DRV_MAGICNUM, 4, int)
#define MOTOR_DRV_SET_PARA _IOW(MOTOR_DRV_MAGICNUM, 5, sunxi_motor_para_t)
#define MOTOR_DRV_SET_CMD _IOW(MOTOR_DRV_MAGICNUM, 6, sunxi_motor_cmd_t)
#define MOTOR_DRV_GET_CMD _IOR(MOTOR_DRV_MAGICNUM, 7, sunxi_motor_cmd_t)
#define MOTOR_DRV_GET_STATUS \
_IOR(MOTOR_DRV_MAGICNUM, 8, sunxi_motor_device_status_t)
#define MOTOR_DRV_SET_STATUS \
_IOR(MOTOR_DRV_MAGICNUM, 9, sunxi_motor_device_status_t)
void show_usage(void)
printf("Usage: gpio_motor <mode> <direction> <steps> <time_per_step> <block>\n");
printf(" - mode:\n");
printf(" 0: Control via file IO\n");
printf(" 1: Control via IOCTL\n");
printf(" 2: Terminate non-blocking movement\n");
printf(" 3: Get movement parameters\n");
printf(" - direction:\n");
printf(" 1: DIR_UP\n");
printf(" 2: DIR_DOWN\n");
printf(" 3: DIR_RIGHT\n");
printf(" 4: DIR_LEFT\n");
printf(" 5: DIR_LEFT_UP\n");
printf(" 6: DIR_RIGHT_UP\n");
printf(" 7: DIR_LEFT_DOWN\n");
printf(" 8: DIR_RIGHT_DOWN\n");
printf(" - block:\n");
printf(" 0: Non-blocking mode\n");
printf(" 1: Blocking mode\n");
printf("\nExample:\n");
printf("gpio_motor 0 1 100 1 1\n");
printf(" - Use file system mode\n");
printf(" - Direction: up\n");
printf(" - Move 100 steps\n");
printf(" - Time per step: 1000us\n");
printf(" - Blocking mode\n");
int fd, mode = 0;
sunxi_motor_device_status_t status;
sunxi_motor_cmd_t cmd;
if (argc != 6) {
show_usage();
return 1;
mode = atoi(argv[1]);
cmd.ab_step = atoi(argv[3]);
cmd.ab_time_per_step = atoi(argv[4]);
cmd.cd_step = atoi(argv[3]);
cmd.cd_time_per_step = atoi(argv[4]);
cmd.block = atoi(argv[5]);
switch (atoi(argv[2])) {
case 1:
cmd.dir = DIR_UP << DIR_AB_SHIFT;
case 2:
cmd.dir = DIR_DOWN << DIR_AB_SHIFT;
case 3:
cmd.dir = DIR_RIGHT << DIR_CD_SHIFT;
case 4:
cmd.dir = DIR_LEFT << DIR_CD_SHIFT;
case 5:
cmd.dir = (DIR_LEFT << DIR_CD_SHIFT) | (DIR_UP << DIR_AB_SHIFT);
case 6:
cmd.dir = (DIR_RIGHT << DIR_CD_SHIFT) | (DIR_UP << DIR_AB_SHIFT);
case 7:
cmd.dir = (DIR_LEFT << DIR_CD_SHIFT) | (DIR_DOWN << DIR_AB_SHIFT);
case 8:
cmd.dir = (DIR_RIGHT << DIR_CD_SHIFT) | (DIR_DOWN << DIR_AB_SHIFT);
default:
cmd.dir = 0;
fd = open("/dev/sunxi_gpio_motor", O_RDWR);
if (fd == -1) {
perror("Failed to open the device node");
return 1;
if (mode == 0) {
if (write(fd, &cmd, sizeof(sunxi_motor_cmd_t)) < 0) {
perror("Failed to write to the device...");
close(fd);
} else if (mode == 1) {
if (ioctl(fd, MOTOR_DRV_SET_CMD, &cmd) == -1) {
perror("Failed to perform ioctl MOTOR_DRV_SET_DATA");
close(fd);
return errno;
} else if (mode == 2) {
if (ioctl(fd, MOTOR_DRV_SET_STOP, NULL) == -1) {
perror("Failed to perform ioctl MOTOR_DRV_GET_DATA");
close(fd);
return errno;
if (read(fd, &status, sizeof(sunxi_motor_device_status_t)) !=
sizeof(sunxi_motor_device_status_t)) {
perror("Failed to read status from the device node");
close(fd);
return 1;
printf("x: %d\n", status.x);
printf("y: %d\n", status.y);
printf("dir: %d\n", status.dir);
printf("status: %d\n", status.status);
close(fd);
return 1;
close(fd);
关键结构体与常量
电机运动方向常量 (DIR_*):
  • DIR_UPDIR_DOWNDIR_RIGHTDIR_LEFT 分别表示电机的基本运动方向。
  • DIR_AB_SHIFTDIR_CD_SHIFT 是用于控制电机在 A/B(垂直方向)和 C/D(水平方向)上的运动位移。
电机状态结构体 (sunxi_motor_device_status_t):
  • 保存电机的状态信息,包括当前的 xy 坐标、运动方向以及电机的状态。
int x; /* 电机在 X 方向的步数 */
int y; /* 电机在 Y 方向的步数 */
int dir; /* 电机的运动方向 */
int status; /* 电机的状态 */
电机命令结构体 (sunxi_motor_cmd_t):
  • 包含了控制电机的参数,如方向、步数、每步时间、以及是否阻塞等。
int dir; /* 电机命令的运动方向 */
int ab_step; /* 电机在垂直方向的步数 */
int ab_time_per_step; /* 电机在垂直方向每步的时间 */
int cd_step; /* 电机在水平方向的步数 */
int cd_time_per_step; /* 电机在水平方向每步的时间 */
int block; /* 是否阻塞的标志 */
IOCTL 命令定义:
  • 用于与电机驱动交互的各种 IOCTL 命令:
    • MOTOR_DRV_SET_CMD 用来发送电机命令。
    • MOTOR_DRV_GET_CMD 用来获取当前电机命令。
    • MOTOR_DRV_SET_STOP 和其他命令用来停止电机或设置电机状态。
#define MOTOR_DRV_GET_STATUS _IOR(MOTOR_DRV_MAGICNUM, 8, sunxi_motor_device_status_t)
#define MOTOR_DRV_SET_STATUS _IOR(MOTOR_DRV_MAGICNUM, 9, sunxi_motor_device_status_t)
主函数流程
命令行参数:
程序接受 5 个命令行参数:
  • mode:指定操作模式(例如文件 I/O 或 IOCTL)。
  • direction:定义电机的运动方向。
  • steps:电机移动的步数。
  • time_per_step:每步的时间(单位为微秒)。
  • block:指定是否为阻塞模式。
设置电机命令:
根据传入的 direction 参数,计算出对应的运动方向,使用移位操作(例如 DIR_UPDIR_DOWN 等)来设置电机的方向。方向信息会根据 DIR_AB_SHIFTDIR_CD_SHIFT 放入 cmd.dir
打开设备文件:
通过 open() 函数打开 /dev/sunxi_gpio_motor 设备文件。如果打开失败,会打印错误信息并退出程序。
根据模式执行操作:
根据 mode 参数的不同,程序执行不同的操作:
  • 模式 0(文件 I/O):通过 write() 将电机命令写入设备。
  • 模式 1(IOCTL):通过 ioctl() 发送电机命令。
  • 模式 2(停止电机):使用 MOTOR_DRV_SET_STOP 命令停止电机。
  • 模式 3(获取电机状态):使用 MOTOR_DRV_GET_STATUS 命令获取电机状态,并打印出来。
读取电机状态:
执行命令后,程序会通过 MOTOR_DRV_GET_STATUS IOCTL 命令读取电机的状态,并输出当前的 xy 坐标、方向和状态。
关闭设备:
最后,程序使用 close() 函数关闭设备文件。
示例用法
  • 模式 0:文件系统模式。让电机以 100 步向上移动,每步 1000 微秒,阻塞模式:
gpio_motor 0 1 100 1000 1
  • 模式 1:IOCTL 模式。与文件系统模式类似,但使用 IOCTL 控制电机:
gpio_motor 1 1 100 1000 1
  • 模式 2:停止电机:
gpio_motor 2 1 0 0 0
  • 模式 3:获取电机当前状态:
gpio_motor 3 0 0 0 0
