DBI 驱动 ST7789V 3.5 寸 LCD
此次适配的 SPI 屏为 jlt35031c ,使用的是 DBI 进行驱动。
image-20250324091246203
引脚配置如下:
V861TFT 模块
PD1CS
PD2SCK
PD3MOSI
3V3BLK (PWM)
PD4RESET
PD5RS
3V3VCC
GNDGND
备注
备注
备注
备注
屏幕的 MISO 引脚由于没有实际使用,这里将 MISO 接到 PD6,这个脚由于不使用所以不接也可以
驱动配置
设置 SPI 驱动
勾选以下驱动:
Allwinner BSP  --->
Device Drivers --->
SPI NG Drivers --->
<*> SPI NG Driver Support for Allwinner SoCs
[*] Support driver bit-aligned feature
[*] Support driver dbi feature
[*] Support driver camera feature
[*] Support atomic xfer function
image-20250322174739865
编写 SPI LCD 显示屏驱动
整理后的初始化代码如下:
sunxi_lcd_cmd_write(sel, 0x11);
sunxi_lcd_para_write(sel, 0x00);
sunxi_lcd_delay_ms(120);
sunxi_lcd_cmd_write(sel, 0xf0);
sunxi_lcd_para_write(sel, 0xc3);
sunxi_lcd_para_write(sel, 0x96);
sunxi_lcd_para_write(sel, 0x48);
sunxi_lcd_cmd_write(sel, 0xb4);
sunxi_lcd_para_write(sel, 0x01);
sunxi_lcd_cmd_write(sel, 0xb7);
sunxi_lcd_para_write(sel, 0xc6);
sunxi_lcd_cmd_write(sel, 0xe8);
sunxi_lcd_para_write(sel, 0x40);
sunxi_lcd_cmd_write(sel, 0x8a);
sunxi_lcd_cmd_write(sel, 0x00);
sunxi_lcd_para_write(sel, 0x29);
sunxi_lcd_cmd_write(sel, 0x19);
sunxi_lcd_para_write(sel, 0xa5);
sunxi_lcd_cmd_write(sel, 0x33);
sunxi_lcd_cmd_write(sel, 0xc1);
sunxi_lcd_para_write(sel, 0x06);
sunxi_lcd_cmd_write(sel, 0xc2);
sunxi_lcd_para_write(sel, 0xa7);
sunxi_lcd_cmd_write(sel, 0xc5);
sunxi_lcd_para_write(sel, 0x18);
sunxi_lcd_cmd_write(sel, 0xe0);
sunxi_lcd_para_write(sel, 0xf0);
sunxi_lcd_para_write(sel, 0x09);
sunxi_lcd_para_write(sel, 0x0b);
sunxi_lcd_para_write(sel, 0x04);
sunxi_lcd_para_write(sel, 0x15);
sunxi_lcd_para_write(sel, 0x2f);
sunxi_lcd_para_write(sel, 0x54);
sunxi_lcd_para_write(sel, 0x42);
sunxi_lcd_para_write(sel, 0x3c);
sunxi_lcd_para_write(sel, 0x17);
sunxi_lcd_para_write(sel, 0x14);
sunxi_lcd_para_write(sel, 0x1b);
sunxi_lcd_cmd_write(sel, 0xE1);
sunxi_lcd_para_write(sel, 0x03);
sunxi_lcd_para_write(sel, 0x2d);
sunxi_lcd_para_write(sel, 0x43);
sunxi_lcd_para_write(sel, 0x3b);
sunxi_lcd_para_write(sel, 0x16);
sunxi_lcd_para_write(sel, 0x69);
sunxi_lcd_cmd_write(sel, 0x3a);
sunxi_lcd_para_write(sel, 0x55);
/* Display ON */
sunxi_lcd_cmd_write(sel, 0x29);
/* LCD_DISPLAY_ROTATION_0 */
/* LCD_DISPLAY_ROTATION_90
sunxi_lcd_para_write(sel, 0xe8); */
/* LCD_DISPLAY_ROTATION_180
sunxi_lcd_para_write(sel, 0x88); */
/* LCD_DISPLAY_ROTATION_27
sunxi_lcd_para_write(sel, 0x28); */
/* set_screen_size */
sunxi_lcd_cmd_write(sel, 0x2a);
sunxi_lcd_para_write(sel, 0x3f);
sunxi_lcd_cmd_write(sel, 0x2b);
sunxi_lcd_para_write(sel, 0xdf);
address(sel, 0, 0, info[sel].lcd_x - 1, info[sel].lcd_y - 1);
address(sel, 0, 0, info[sel].lcd_y - 1, info[sel].lcd_x - 1);
对照屏厂提供的驱动修改 address 函数,做如下修改
static void address(unsigned int sel, int x, int y, int width, int height)
sunxi_lcd_cmd_write(sel, 0x2a); /* Set coloum address */
sunxi_lcd_para_write(sel, (((x + lcd_dev_xoffset) >> 8) & 0xff));
sunxi_lcd_para_write(sel, ((x + lcd_dev_xoffset) & 0xff));
sunxi_lcd_para_write(sel, ((width + lcd_dev_xoffset >> 8) & 0xff));
sunxi_lcd_para_write(sel, ((width + lcd_dev_xoffset) & 0xff));
sunxi_lcd_cmd_write(sel, 0x2b); /* Set row address */
sunxi_lcd_para_write(sel, ((y + lcd_dev_yoffset >> 8) & 0xff));
sunxi_lcd_para_write(sel, ((y + lcd_dev_yoffset) & 0xff));
sunxi_lcd_para_write(sel, ((height + lcd_dev_yoffset >> 8) & 0xff));
sunxi_lcd_para_write(sel, ((height + lcd_dev_yoffset) & 0xff));
sunxi_lcd_cmd_write(sel, 0x2c);
完成驱动如下
#include "jlt35031c.h"
#define RESET(s, v) sunxi_lcd_gpio_set_value(s, 0, v)
#define power_en(sel, val) sunxi_lcd_gpio_set_value(sel, 0, val)
static uint16_t lcd_dev_xoffset = 0;
static uint16_t lcd_dev_yoffset = 0;
static struct disp_panel_para info[LCD_FB_MAX];
static void LCD_panel_init(unsigned int sel)
unsigned int rotate;
if (bsp_disp_get_panel_info(sel, &info[sel])) {
lcd_fb_wrn("get panel info fail!\n");
return;
/* Display ON */
if (info[sel].lcd_x < info[sel].lcd_y)
static void LCD_panel_exit(unsigned int sel)
sunxi_lcd_cmd_write(sel, 0x28);
sunxi_lcd_delay_ms(20);
sunxi_lcd_cmd_write(sel, 0x10);
sunxi_lcd_pin_cfg(sel, 0);
lcd_fb_here;
LCD_OPEN_FUNC(sel, LCD_power_on, 50);
LCD_OPEN_FUNC(sel, LCD_panel_init, 200);
LCD_OPEN_FUNC(sel, lcd_fb_black_screen, 50);
lcd_fb_here;
lcd_fb_here;
power_en(sel, 1);
sunxi_lcd_pin_cfg(sel, 1);
RESET(sel, 1);
sunxi_lcd_delay_ms(100);
RESET(sel, 0);
RESET(sel, 1);
lcd_fb_here;
sunxi_lcd_pwm_enable(sel);
lcd_fb_here;
sunxi_lcd_pwm_disable(sel);
lcd_fb_here;
static int lcd_set_var(unsigned int sel, struct fb_info *p_info)
static int lcd_blank(unsigned int sel, unsigned int en)
static int lcd_set_addr_win(unsigned int sel, int x, int y, int width, int height)
address(sel, x, y, width, height);
struct __lcd_panel jlt35031c_panel = {
/* panel driver name, must mach the name of lcd_drv_name in sys_config.fex */
.name = "jlt35031c",
.func = {
.blank = lcd_blank,
.set_var = lcd_set_var,
.set_addr_win = lcd_set_addr_win,
配置设备树
&pio {
spi1_pins_default: spi1@0 {
pins = "PD1", "PD2", "PD3"; /* CS, SCK, SDA */
function = "spi1";
allwinner,drive = <3>;
spi1_pins_hold: spi1@1 {
pins = "PD5"; /* DC */
function = "spi1_hold";
bias-pull-up;
spi1_pins_sleep: spi1@2 {
pins = "PD1", "PD2", "PD3", "PD5";
function = "io_disabled";
&lcd_fb {
port {
#address-cells = <1>;
#size-cells = <0>;
spi_panel0: endpoint@0 {
reg = <0>;
remote-endpoint = <&panel_jlt35031c_spi1>;
&spi1 {
pinctrl-0 = <&spi1_pins_default &spi1_pins_hold>;
sunxi,spi-bus-mode = <SUNXI_SPI_BUS_DBI>;
panel_jlt35031c_spi1: slave@0 {
device_type = "spi-panel";
reg = <0x0>;
lcd_used = <1>;
lcd_driver_name = "jlt35031c";
lcd_if = <1>;
lcd_dbi_if = <2>;
lcd_data_speed = <150>;
lcd_spi_bus_num = <1>;
lcd_x = <320>;
lcd_y = <480>;
lcd_pixel_fmt = <10>;
lcd_dbi_fmt = <2>;
lcd_rgb_order = <0>;
lcd_width = <60>;
lcd_height = <60>;
lcd_pwm_used = <0>;
lcd_pwm_ch = <6>;
lcd_pwm_freq = <5000>;
lcd_pwm_pol = <1>;
lcd_frm = <1>;
lcd_gamma_en = <1>;
fb_buffer_num = <2>;
lcd_backlight = <100>;
lcd_fps = <60>;
lcd_dbi_te = <0>;
lcd_dbi_clk_mode = <1>;
功能测试
勾选 LVGL,运行测试
lv_examples 1
屏幕可以正常显示,帧率正确即可。
