DBI 驱动 ST7789V 1.3 寸 LCD
平台提供了 SPI DBI 的 SPI TFT 接口,具有如下特点:
  • Supports DBI Type C 3 Line/4 Line Interface Mode
  • Supports 2 Data Lane Interface Mode
  • Supports data source from CPU or DMA
  • Supports RGB111/444/565/666/888 video format
  • Maximum resolution of RGB666 240 x 320@30Hz with single data lane
  • Maximum resolution of RGB888 240 x 320@60Hz or 320 x 480@30Hz with dual data lane
  • Supports tearing effect
  • Supports software flexible control video frame rate
同时,提供了 LCD_FB 驱动框架以供 SPI 屏幕使用。
此次适配的SPI屏为 ZJY130S0800TG01,使用的是 SPI 进行驱动。
image-20250322173114246
引脚配置如下:
V861TFT 模块
PD1CS
PD2SCL
PD3SDA
3V3BLK
PD4RES
PD5DC
3V3VCC
GNDGND
驱动配置
设置 SPI 驱动
勾选以下驱动:
Allwinner BSP  --->
Device Drivers --->
SPI NG Drivers --->
<*> SPI NG Driver Support for Allwinner SoCs
[*] Support driver bit-aligned feature
[*] Support driver dbi feature
[*] Support driver camera feature
[*] Support atomic xfer function
image-20250322174739865
编写 SPI LCD 显示屏驱动
获取屏幕初始化序列
首先询问屏厂提供驱动源码
image-20231023102239928
找到 LCD 的初始化序列代码
image-20231023102252129
找到屏幕初始化的源码
image-20231023102333476
整理后的初始化代码如下:
LCD_WR_REG(0x11); // Sleep out
delay_ms(120); // Delay 120ms
//************* Start Initial Sequence **********//
LCD_WR_REG(0x36);
LCD_WR_DATA8(0x00);
LCD_WR_REG(0x3A);
LCD_WR_DATA8(0x05);
LCD_WR_REG(0xB2);
LCD_WR_DATA8(0x1F);
LCD_WR_DATA8(0x1F);
LCD_WR_DATA8(0x00);
LCD_WR_DATA8(0x33);
LCD_WR_DATA8(0x33);
LCD_WR_REG(0xB7);
LCD_WR_DATA8(0x35);
LCD_WR_REG(0xBB);
LCD_WR_DATA8(0x20); // 2b
LCD_WR_REG(0xC0);
LCD_WR_DATA8(0x2C);
LCD_WR_REG(0xC2);
LCD_WR_DATA8(0x01);
LCD_WR_REG(0xC3);
LCD_WR_DATA8(0x01);
LCD_WR_REG(0xC4);
LCD_WR_DATA8(0x18); // VDV, 0x20:0v
LCD_WR_REG(0xC6);
LCD_WR_DATA8(0x13); // 0x13:60Hz
LCD_WR_REG(0xD0);
LCD_WR_DATA8(0xA4);
LCD_WR_DATA8(0xA1);
LCD_WR_REG(0xD6);
LCD_WR_DATA8(0xA1); // sleep in后,gate输出为GND
LCD_WR_REG(0xE0);
LCD_WR_DATA8(0xF0);
LCD_WR_DATA8(0x04);
LCD_WR_DATA8(0x07);
LCD_WR_DATA8(0x04);
LCD_WR_DATA8(0x04);
LCD_WR_DATA8(0x04);
LCD_WR_DATA8(0x25);
LCD_WR_DATA8(0x33);
LCD_WR_DATA8(0x3C);
LCD_WR_DATA8(0x36);
LCD_WR_DATA8(0x14);
LCD_WR_DATA8(0x12);
LCD_WR_DATA8(0x29);
LCD_WR_DATA8(0x30);
LCD_WR_REG(0xE1);
LCD_WR_DATA8(0xF0);
LCD_WR_DATA8(0x02);
LCD_WR_DATA8(0x04);
LCD_WR_DATA8(0x05);
LCD_WR_DATA8(0x05);
LCD_WR_DATA8(0x21);
LCD_WR_DATA8(0x25);
LCD_WR_DATA8(0x32);
LCD_WR_DATA8(0x3B);
LCD_WR_DATA8(0x38);
LCD_WR_DATA8(0x12);
LCD_WR_DATA8(0x14);
LCD_WR_DATA8(0x27);
LCD_WR_DATA8(0x31);
LCD_WR_REG(0xE4);
LCD_WR_DATA8(0x1D); // 使用240根gate (N+1)*8
LCD_WR_DATA8(0x00); // 设定gate起点位置
LCD_WR_DATA8(0x00); // 当gate没有用完时,bit4(TMG)设为0
LCD_WR_REG(0x21);
LCD_WR_REG(0x29);
用现成驱动改写 SPI LCD 驱动
选择一个现成的 SPI LCD 改写即可,这里选择 nv3029s.c 驱动来修改。复制这两个驱动,重命名为 st7789v.c
image-20231017104740060
先编辑 st7789v.hnv3029s 改成 st7789v
image-20231017104851772
#ifndef _ST7789V_H
#define _ST7789V_H
#include "panels.h"
struct __lcd_panel st7789v_panel;
#endif /*End of file*/
编辑 st7789v.cnv3029s 改成 st7789v
image-20231017104942286
编写初始化序列
先删除 static void LCD_panel_init(unsigned int sel) 中的初始化函数。
image-20231017105101421
然后将屏厂提供的初始化序列复制进来
image-20231023102641761
然后按照 spi_lcd 框架的接口改写驱动接口,具体接口如下
屏厂函数SPILCD框架接口
LCD_WR_REGsunxi_lcd_cmd_write
LCD_WR_DATA8sunxi_lcd_para_write
delay_mssunxi_lcd_delay_ms
可以直接进行替换
image-20231023095114146
完成后如下
image-20231023095158411
然后对照屏厂提供的驱动修改 address 函数
image-20231023102549896
做如下修改
static void address(unsigned int sel, int x, int y, int width, int height)
sunxi_lcd_cmd_write(sel, 0x2B); /* Set row address */
sunxi_lcd_para_write(sel, (y >> 8) & 0xff);
sunxi_lcd_para_write(sel, y & 0xff);
sunxi_lcd_para_write(sel, (height >> 8) & 0xff);
sunxi_lcd_para_write(sel, height & 0xff);
sunxi_lcd_cmd_write(sel, 0x2A); /* Set coloum address */
sunxi_lcd_para_write(sel, (x >> 8) & 0xff);
sunxi_lcd_para_write(sel, x & 0xff);
sunxi_lcd_para_write(sel, (width >> 8) & 0xff);
sunxi_lcd_para_write(sel, width & 0xff);
sunxi_lcd_cmd_write(sel, 0x2c);
完成驱动如下
#include "st7789v.h"
#define RESET(s, v) sunxi_lcd_gpio_set_value(s, 0, v)
#define power_en(sel, val) sunxi_lcd_gpio_set_value(sel, 0, val)
static struct disp_panel_para info[LCD_FB_MAX];
if (bsp_disp_get_panel_info(sel, &info[sel])) {
lcd_fb_wrn("get panel info fail!\n");
return;
sunxi_lcd_cmd_write(sel, 0x11); // Sleep out
sunxi_lcd_delay_ms(120); // Delay 120ms
sunxi_lcd_para_write(sel, 0x00);
sunxi_lcd_cmd_write(sel, 0x3A);
sunxi_lcd_para_write(sel, 0x05);
sunxi_lcd_cmd_write(sel, 0xB2);
sunxi_lcd_para_write(sel, 0x1F);
sunxi_lcd_para_write(sel, 0x33);
sunxi_lcd_cmd_write(sel, 0xB7);
sunxi_lcd_para_write(sel, 0x35);
sunxi_lcd_cmd_write(sel, 0xBB);
sunxi_lcd_para_write(sel, 0x20); // 2b
sunxi_lcd_cmd_write(sel, 0xC0);
sunxi_lcd_para_write(sel, 0x2C);
sunxi_lcd_cmd_write(sel, 0xC2);
sunxi_lcd_para_write(sel, 0x01);
sunxi_lcd_cmd_write(sel, 0xC3);
sunxi_lcd_cmd_write(sel, 0xC4);
sunxi_lcd_para_write(sel, 0x18); // VDV, 0x20:0v
sunxi_lcd_cmd_write(sel, 0xC6);
sunxi_lcd_para_write(sel, 0x13); // 0x13:60Hz
sunxi_lcd_cmd_write(sel, 0xD0);
sunxi_lcd_para_write(sel, 0xA4);
sunxi_lcd_para_write(sel, 0xA1);
sunxi_lcd_cmd_write(sel, 0xD6);
sunxi_lcd_para_write(sel, 0xA1); // sleep in后,gate输出为GND
sunxi_lcd_cmd_write(sel, 0xE0);
sunxi_lcd_para_write(sel, 0xF0);
sunxi_lcd_para_write(sel, 0x04);
sunxi_lcd_para_write(sel, 0x07);
sunxi_lcd_para_write(sel, 0x25);
sunxi_lcd_para_write(sel, 0x3C);
sunxi_lcd_para_write(sel, 0x36);
sunxi_lcd_para_write(sel, 0x14);
sunxi_lcd_para_write(sel, 0x12);
sunxi_lcd_para_write(sel, 0x29);
sunxi_lcd_para_write(sel, 0x30);
sunxi_lcd_cmd_write(sel, 0xE1);
sunxi_lcd_para_write(sel, 0x02);
sunxi_lcd_para_write(sel, 0x21);
sunxi_lcd_para_write(sel, 0x32);
sunxi_lcd_para_write(sel, 0x3B);
sunxi_lcd_para_write(sel, 0x38);
sunxi_lcd_para_write(sel, 0x27);
sunxi_lcd_para_write(sel, 0x31);
sunxi_lcd_cmd_write(sel, 0xE4);
sunxi_lcd_para_write(sel, 0x1D); // 使用240根gate (N+1)*8
sunxi_lcd_para_write(sel, 0x00); // 设定gate起点位置
sunxi_lcd_para_write(sel, 0x00); // 当gate没有用完时,bit4(TMG)设为0
sunxi_lcd_cmd_write(sel, 0x21);
sunxi_lcd_cmd_write(sel, 0x29);
if (info[sel].lcd_x < info[sel].lcd_y)
address(sel, 0, 0, info[sel].lcd_x - 1, info[sel].lcd_y - 1);
address(sel, 0, 0, info[sel].lcd_y - 1, info[sel].lcd_x - 1);
static void LCD_panel_exit(unsigned int sel)
sunxi_lcd_cmd_write(sel, 0x28);
sunxi_lcd_delay_ms(20);
sunxi_lcd_cmd_write(sel, 0x10);
sunxi_lcd_pin_cfg(sel, 0);
lcd_fb_here;
LCD_OPEN_FUNC(sel, LCD_power_on, 50);
LCD_OPEN_FUNC(sel, LCD_panel_init, 200);
LCD_OPEN_FUNC(sel, lcd_fb_black_screen, 50);
lcd_fb_here;
lcd_fb_here;
power_en(sel, 1);
sunxi_lcd_pin_cfg(sel, 1);
RESET(sel, 1);
sunxi_lcd_delay_ms(100);
RESET(sel, 0);
RESET(sel, 1);
lcd_fb_here;
power_en(sel, 0);
sunxi_lcd_pwm_enable(sel);
lcd_fb_here;
sunxi_lcd_pwm_disable(sel);
lcd_fb_here;
/* sel: 0:lcd0; 1:lcd1 */
static s32 LCD_user_defined_func(u32 sel, u32 para1, u32 para2, u32 para3)
lcd_fb_here;
static int lcd_set_var(unsigned int sel, struct fb_info *p_info)
static int lcd_set_addr_win(unsigned int sel, int x, int y, int width, int height)
address(sel, x, y, width, height);
static int lcd_blank(unsigned int sel, unsigned int en)
struct __lcd_panel st7789v_panel = {
/* panel driver name, must mach the name of lcd_drv_name in sys_config.fex
.name = "st7789v",
.func = {
.lcd_user_defined_func = LCD_user_defined_func,
.blank = lcd_blank,
.set_var = lcd_set_var,
.set_addr_win = lcd_set_addr_win,
对接驱动框架
完成了屏幕驱动的编写,接下来需要对接到 SPILCD 驱动框架。首先编辑 Kconfig,增加 st7789v 的配置
image-20231017105814814
config LCD_SUPPORT_ST7789V
bool "LCD support st7789v panel"
default n
---help---
If you want to support st7789v panel for display driver, select it.
然后编辑 panels.cpanel_array 里增加 st7789 驱动的引用
image-20231017105948156
如下图
image-20231017105919628
#ifdef CONFIG_LCD_SUPPORT_ST7789V
&st7789v_panel,
之后编辑 panels.h 同样增加引用
image-20231017110043805
如下图
image-20231017110122397
extern struct __lcd_panel st7789v_panel;
最后编辑外层的 Makefile 增加编译选项,如下所示
image-20231017110242997
obj-${CONFIG_LCD_SUPPORT_ST7789V} += panels/st7789v.o
选择驱动
进入内核驱动配置界面,勾选新增的驱动
Allwinner BSP  --->
Device Drivers --->
Video Drivers --->
SPI LCD Panel Drivers --->
LCD FB Panels select --->
[*] LCD support st7789v panel
image-20250322174411104
配置设备树
&pio {
spi1_pins_default: spi1@0 {
pins = "PD1", "PD2", "PD3"; /* CS, SCK, SDA */
function = "spi1";
allwinner,drive = <3>;
spi1_pins_hold: spi1@1 {
pins = "PD5"; /* DC */
function = "spi1_hold";
bias-pull-up;
spi1_pins_sleep: spi1@2 {
pins = "PD1", "PD2", "PD3", "PD5";
function = "io_disabled";
&lcd_fb {
port {
#address-cells = <1>;
#size-cells = <0>;
spi_panel0: endpoint@0 {
reg = <0>;
&spi1 {
pinctrl-0 = <&spi1_pins_default &spi1_pins_hold>;
sunxi,spi-bus-mode = <SUNXI_SPI_BUS_DBI>;
panel_st7789v_spi1: slave@0 {
device_type = "spi-panel";
reg = <0x0>;
lcd_used = <1>;
lcd_driver_name = "st7789v";
lcd_if = <1>;
lcd_dbi_if = <2>;
lcd_data_speed = <48>;
lcd_x = <240>;
lcd_y = <240>;
lcd_pixel_fmt = <10>;
lcd_dbi_fmt = <2>;
lcd_rgb_order = <0>;
lcd_width = <60>;
lcd_height = <60>;
lcd_pwm_used = <0>;
lcd_pwm_ch = <6>;
lcd_pwm_freq = <5000>;
lcd_pwm_pol = <1>;
lcd_frm = <1>;
lcd_gamma_en = <1>;
fb_buffer_num = <2>;
lcd_backlight = <100>;
lcd_fps = <60>;
lcd_dbi_te = <0>;
lcd_dbi_clk_mode = <0>;
功能测试
勾选 LVGL,运行测试
lv_examples 1
屏幕可以正常显示,帧率正确即可。
