使用 OpenCV 捕获摄像头并且输出到屏幕上
快速测试​
这个 DEMO 也已经包含在 tina-bsp-tinyvision.tar.gz 中了,可以快速测试这个 DEMO
运行 m menuconfig
OpenCV  --->
<*> opencv....................................................... opencv libs
[*] Enabel sunxi vin isp support
<*> opencv_camera.............................opencv_camera and display image
源码详解​
编写一个程序,使用 OpenCV 捕获摄像头输出并且显示到屏幕上,程序如下:
#include <fcntl.h>
#include <fstream>
#include <iostream>
#include <linux/fb.h>
#include <signal.h>
#include <stdint.h>
#include <sys/ioctl.h>
#include <opencv2/opencv.hpp>
#define DISPLAY_X 240
#define DISPLAY_Y 240
static cv::VideoCapture cap;
struct framebuffer_info {
uint32_t bits_per_pixel;
uint32_t xres_virtual;
struct framebuffer_info get_framebuffer_info(const char* framebuffer_device_path)
struct framebuffer_info info;
struct fb_var_screeninfo screen_info;
int fd = -1;
fd = open(framebuffer_device_path, O_RDWR);
if (fd >= 0) {
if (!ioctl(fd, FBIOGET_VSCREENINFO, &screen_info)) {
info.xres_virtual = screen_info.xres_virtual;
info.bits_per_pixel = screen_info.bits_per_pixel;
return info;
/* Signal handler */
static void terminate(int sig_no)
printf("Got signal %d, exiting ...\n", sig_no);
cap.release();
exit(1);
static void install_sig_handler(void)
signal(SIGBUS, terminate);
signal(SIGFPE, terminate);
signal(SIGHUP, terminate);
signal(SIGILL, terminate);
signal(SIGINT, terminate);
signal(SIGIOT, terminate);
signal(SIGPIPE, terminate);
signal(SIGQUIT, terminate);
signal(SIGSEGV, terminate);
signal(SIGSYS, terminate);
signal(SIGTERM, terminate);
signal(SIGTRAP, terminate);
signal(SIGUSR1, terminate);
signal(SIGUSR2, terminate);
int main(int, char**)
const int frame_width = 480;
const int frame_height = 480;
const int frame_rate = 30;
install_sig_handler();
framebuffer_info fb_info = get_framebuffer_info("/dev/fb0");
cap.open(0);
if (!cap.isOpened()) {
std::cerr << "Could not open video device." << std::endl;
return 1;
std::cout << "Successfully opened video device." << std::endl;
cap.set(cv::CAP_PROP_FRAME_WIDTH, frame_width);
cap.set(cv::CAP_PROP_FRAME_HEIGHT, frame_height);
cap.set(cv::CAP_PROP_FPS, frame_rate);
std::ofstream ofs("/dev/fb0");
cv::Mat frame;
cv::Mat trams_temp_fream;
cv::Mat yuv_frame;
while (true) {
cap >> frame;
if (frame.depth() != CV_8U) {
std::cerr << "Not 8 bits per pixel and channel." << std::endl;
} else if (frame.channels() != 3) {
std::cerr << "Not 3 channels." << std::endl;
cv::transpose(frame, frame);
cv::flip(frame, frame, 0);
cv::resize(frame, frame, cv::Size(DISPLAY_X, DISPLAY_Y));
int framebuffer_width = fb_info.xres_virtual;
int framebuffer_depth = fb_info.bits_per_pixel;
cv::Size2f frame_size = frame.size();
cv::Mat framebuffer_compat;
switch (framebuffer_depth) {
case 16:
cv::cvtColor(frame, framebuffer_compat, cv::COLOR_BGR2BGR565);
for (int y = 0; y < frame_size.height; y++) {
ofs.seekp(y * framebuffer_width * 2);
ofs.write(reinterpret_cast<char*>(framebuffer_compat.ptr(y)), frame_size.width * 2);
case 32: {
std::vector<cv::Mat> split_bgr;
cv::split(frame, split_bgr);
split_bgr.push_back(cv::Mat(frame_size, CV_8UC1, cv::Scalar(255)));
cv::merge(split_bgr, framebuffer_compat);
ofs.seekp(y * framebuffer_width * 4);
ofs.write(reinterpret_cast<char*>(framebuffer_compat.ptr(y)), frame_size.width * 4);
} break;
default:
std::cerr << "Unsupported depth of framebuffer." << std::endl;
第一部分,处理 frame_buffer 信息:
// 引入头文件
#include <fcntl.h>
#include <fstream>
#include <iostream>
#include <signal.h>
#include <stdint.h>
// 定义显示屏宽度和高度
static cv::VideoCapture cap; // 视频流捕获对象
// 帧缓冲信息结构体
uint32_t bits_per_pixel; // 每个像素的位数
uint32_t xres_virtual; // 虚拟屏幕的宽度
// 获取帧缓冲信息函数
int fd = -1;
// 打开帧缓冲设备文件
if (fd >= 0) {
// 通过 ioctl 获取屏幕信息
info.xres_virtual = screen_info.xres_virtual; // 虚拟屏幕的宽度
info.bits_per_pixel = screen_info.bits_per_pixel; // 每个像素的位数
return info;
这段代码定义了一些常量、全局变量以及两个函数,并给出了相应的注释说明。具体注释如下:
  • #define DISPLAY_X 240:定义显示屏的宽度为240。
  • #define DISPLAY_Y 240:定义显示屏的高度为240。
  • static cv::VideoCapture cap;:定义一个静态的OpenCV视频流捕获对象,用于捕获视频流。
  • struct framebuffer_info:定义了一个帧缓冲信息的结构体。
    • uint32_t bits_per_pixel:每个像素的位数。
    • uint32_t xres_virtual:虚拟屏幕的宽度。
  • struct framebuffer_info get_framebuffer_info(const char* framebuffer_device_path):获取帧缓冲信息的函数。
    • const char* framebuffer_device_path:帧缓冲设备文件的路径。
    • int fd = -1;:初始化文件描述符为-1。
    • fd = open(framebuffer_device_path, O_RDWR);:打开帧缓冲设备文件,并将文件描述符保存在变量fd中。
    • if (fd >= 0):检查文件是否成功打开。
    • if (!ioctl(fd, FBIOGET_VSCREENINFO, &screen_info)):通过ioctl获取屏幕信息,并将信息保存在变量screen_info中。
      • FBIOGET_VSCREENINFO:控制命令,用于获取屏幕信息。
      • &screen_info:屏幕信息结构体的指针。
    • info.xres_virtual = screen_info.xres_virtual;:将屏幕的虚拟宽度保存在帧缓冲信息结构体的字段xres_virtual中。
    • info.bits_per_pixel = screen_info.bits_per_pixel;:将每个像素的位数保存在帧缓冲信息结构体的字段bits_per_pixel中。
    • return info;:返回帧缓冲信息结构体。
第二部分,注册信号处理函数,用于 ctrl-c 之后关闭摄像头,防止下一次使用摄像头出现摄像头仍被占用的情况。
cap.release();
exit(1);
signal(SIGBUS, terminate); // 当程序访问一个不合法的内存地址时发送的信号
signal(SIGFPE, terminate); // 浮点异常信号
signal(SIGHUP, terminate); // 终端断开连接信号
signal(SIGILL, terminate); // 非法指令信号
signal(SIGINT, terminate); // 中断进程信号
signal(SIGIOT, terminate); // IOT 陷阱信号
signal(SIGPIPE, terminate); // 管道破裂信号
signal(SIGQUIT, terminate); // 停止进程信号
signal(SIGSEGV, terminate); // 无效的内存引用信号
signal(SIGSYS, terminate); // 非法系统调用信号
signal(SIGTERM, terminate); // 终止进程信号
signal(SIGTRAP, terminate); // 跟踪/断点陷阱信号
signal(SIGUSR1, terminate); // 用户定义信号1
signal(SIGUSR2, terminate); // 用户定义信号2
这段代码定义了两个函数,并给出了相应的注释说明。具体注释如下:
  • static void terminate(int sig_no):信号处理函数。
    • int sig_no:接收到的信号编号。
    • printf("Got signal %d, exiting ...\n", sig_no);:打印接收到的信号编号。
    • cap.release();:释放视频流捕获对象。
    • exit(1);:退出程序。
  • static void install_sig_handler(void):安装信号处理函数。
    • signal(SIGBUS, terminate);:为SIGBUS信号安装信号处理函数。
    • signal(SIGFPE, terminate);:为SIGFPE信号安装信号处理函数。
    • signal(SIGHUP, terminate);:为SIGHUP信号安装信号处理函数。
    • signal(SIGILL, terminate);:为SIGILL信号安装信号处理函数。
    • signal(SIGINT, terminate);:为SIGINT信号安装信号处理函数。
    • signal(SIGIOT, terminate);:为SIGIOT信号安装信号处理函数。
    • signal(SIGPIPE, terminate);:为SIGPIPE信号安装信号处理函数。
    • signal(SIGQUIT, terminate);:为SIGQUIT信号安装信号处理函数。
    • signal(SIGSEGV, terminate);:为SIGSEGV信号安装信号处理函数。
    • signal(SIGSYS, terminate);:为SIGSYS信号安装信号处理函数。
    • signal(SIGTERM, terminate);:为SIGTERM信号安装信号处理函数。
    • signal(SIGTRAP, terminate);:为SIGTRAP信号安装信号处理函数。
    • signal(SIGUSR1, terminate);:为SIGUSR1信号安装信号处理函数。
    • signal(SIGUSR2, terminate);:为SIGUSR2信号安装信号处理函数。
这段代码的功能是安装信号处理函数,用于捕获和处理不同类型的信号。当程序接收到指定的信号时,会调用terminate函数进行处理。
具体而言,terminate函数会打印接收到的信号编号,并释放视频流捕获对象cap,然后调用exit(1)退出程序。
install_sig_handler函数用于为多个信号注册同一个信号处理函数terminate,使得当这些信号触发时,都会执行相同的处理逻辑。
第三部分,主函数:
install_sig_handler(); // 安装信号处理函数
framebuffer_info fb_info = get_framebuffer_info("/dev/fb0"); // 获取帧缓冲区信息
cap.open(0); // 打开摄像头
return 1;
std::ofstream ofs("/dev/fb0"); // 打开帧缓冲区
cv::Mat frame;
cv::Mat yuv_frame;
while (true) {
cap >> frame; // 读取一帧图像
if (frame.depth() != CV_8U) { // 判断是否为8位每通道像素
} else if (frame.channels() != 3) { // 判断是否为3通道
cv::transpose(frame, frame); // 图像转置
cv::flip(frame, frame, 0); // 图像翻转
cv::resize(frame, frame, cv::Size(DISPLAY_X, DISPLAY_Y)); // 改变图像大小
case 16:
case 32: {
} break;
default:
这段代码主要实现了从摄像头获取图像并将其显示在帧缓冲区中。具体流程如下:
  • 定义了常量frame_width、frame_height和frame_rate表示图像的宽度、高度和帧率。
  • 调用install_sig_handler()函数安装信号处理函数。
  • 调用get_framebuffer_info("/dev/fb0")函数获取帧缓冲区信息。
  • 调用cap.open(0)打开摄像头,并进行错误检查。
  • 调用cap.set()函数设置摄像头的参数。
  • 调用std::ofstream ofs("/dev/fb0")打开帧缓冲区。
  • 循环读取摄像头的每一帧图像,对其进行转置、翻转、缩放等操作,然后将其写入帧缓冲区中。
如果读取的图像不是8位每通道像素或者不是3通道,则会输出错误信息。如果帧缓冲区的深度不受支持,则也会输出错误信息。
